Need opinions on this cam
Old 03-11-2009, 03:45 PM
red98ls1's Avatar
Default Need opinions on this cam
It would be in a 403 CI TT car. 232/236 lift no more than .615 on a 113 LSA
Old 03-11-2009, 05:05 PM
Restricted User
98Z28CobraKiller's Avatar
It's important to know what heads you are using.
Old 03-11-2009, 07:27 PM
red98ls1's Avatar
Good point....Dart Stg III 225's
Old 03-11-2009, 07:34 PM
MY99TAWS6's Avatar
Lots of opinions on cams. Wish mag would dynoetest a bunch of them to try out some different theories and even then people say what works best will depend on the combo of turbos,backpressure etc.
Old 03-11-2009, 07:43 PM
red98ls1's Avatar
I understand all of the 100000 variables. I am just curious if there is one thing or another bad about running this cam in a TT car (ie overlap, not enough duration on one side or the other, etc.).
Old 03-11-2009, 10:24 PM
STAR's Avatar
That cam will work, is it ideal I don't know. Plenty of guys seem to run a dual pattern or reverse pattern cam. Some examples are 235/235 or 228/222 for instance. If you already have that cam and don't want to buy another then it can be used. I personally would choose something smaller, but it also depends on what you are trying to acheive with your build. I suggest you contact a reputable vendor and discuss your goals and possibly have them spec you out a custom grind.
