Please help!!! ASAP
Old 03-14-2009, 02:41 PM
2002RamAir's Avatar
Default Please help!!! ASAP
Doing a turbo install with a new rad... the rad does not have the two little ports by the top of the fill cap.. the one goes to the over flow and the other goes to the throttle body then through it and into a tee fitting that goes into the heads.... Can I just cap this off??
Old 03-14-2009, 02:42 PM
30th t/a's Avatar
I have the one that goes to the TB capped off
Old 03-14-2009, 03:37 PM
cam
cam's Avatar
THe throttle body line is the steam tube. You need to have that hooked up to the highest point in your cooling system. Just search steam tube and you'll find a ton of hits and quick fix tricks
Old 03-14-2009, 05:44 PM
98Camarod's Avatar
If you don't have metal lines, you can by a vent section and put it in between. I ended up drilling and tapping the thermostat housing, some do the water pump.
