STS dropping boost
Old 03-22-2009, 04:56 PM
F-BodyGuy98's Avatar
Default STS dropping boost
the last time i got my dyno'd and tuned with an 8 psi spring in the wastegate it started dropping boost at 6200 rpm to 7.3 psi, but when it was a 5200 it was fine and holding a solid 8... would this be caused by stock valve springs not being able to snap cloesed under the amount of preasure being forced in? or would this happen when you max out a turbo? i have the std turbo that came with the kit, GT67....
Old 03-22-2009, 05:05 PM
RooRnZ28's Avatar
where is your wastegate referenced? the turbo housing or at the intake manifold?
Old 03-22-2009, 05:13 PM
the housing...
Old 03-22-2009, 05:40 PM
whitedevil's Avatar
Relocate to the manifold, doubt you will have an issue then. I am on the same turbo, and have zero issues at all at the same boost level. I would highly recommend upgrading your valve springs though.
Old 03-22-2009, 05:48 PM
RooRnZ28's Avatar
i agree, move the reference to the intake manifold for a more stable reading and see if that fixes it.
Old 03-22-2009, 06:03 PM
well, im going to be getting some 6.0 heads pretty soon and they will be getting stiffer springs...those heads should drop my compression to were i can up the boost a bit right?
Quick Reply: STS dropping boost
