Twins or a Big Single?
Old 04-02-2009, 09:52 PM
InsaneDomestics's Avatar
Default Twins or a Big Single?
Which is better, a Twin Turbo Setup or a BIG Single Turbo Setup? Just wanting to get a few opinions on what some of you guys think.....
InsaneDomestics is offline
Old 04-02-2009, 10:33 PM
lunati397's Avatar
well women have two **** cause it looks better and you can get the job done people look at them and oo and ahhh but one bit tit you can get more done and less work just one nipple to rub more concentration
well thats my opinion
lunati397 is offline
Old 04-02-2009, 10:53 PM
elias_799's Avatar
twins are better, you will have less lag then a single turbo if it is set up properly. but twin turbos are more costly then a single and slightly more complicated.
elias_799 is offline
Old 04-03-2009, 01:22 AM
NA$TY-TA's Avatar
To many varients.... how big of a motor? what trans?? what size single? what size twins..??
Track only??
Your APS setup would be awsome for a street strip car..... a single 88mm is awsome for a street strip car..... a single 106mm is an awsome and very fast strip car... as fast or if not faster then twin 76mm turbo's.....
lots of different things all pending on the goal and duties of the car......
NA$TY-TA is offline
Old 04-03-2009, 05:11 AM
rx_treme's Avatar
That statement is not true.
Read Corky Bell's Maximum Boost book it explains it in detail that a properly setup single will work just as good or better than twins.
General idea is that your motor will only have a given flow of exhaust from it to spool given turbo(s). A big turbo does take longer to spool than a smaller turbo with equal exhaust flow. Now when going twins you have half the exhaust flow but you are not halving the turbo size (rotating mass).
Not to mention;
-twice the parts to buy (wg, turbo, intake & exhaust piping, oiling etc)
-more complicated (twice as much to fail)
-normally heavier (not only w/g and turbos but think about 2 dp's and intakes and ic pipes)
But yes having and seeing TWO turbos does sound so much cooler than just a single.
rx_treme is offline
Old 04-03-2009, 05:48 AM
Denali08's Avatar
Street or pure drag car?
No one mentioned tuning! I think tuning twins might not as easy as single, not sure though.
Denali08 is offline
Old 04-03-2009, 07:29 AM
smokinHawk's Avatar
https://ls1tech.com/forums/forced-in...turbo-faq.html
smokinHawk is offline
Quick Reply: Twins or a Big Single?
