Changing to smaller pulley, high RPM at idle
Old 04-11-2009, 02:23 AM
MikeC5Vert's Avatar
Default Changing to smaller pulley, high RPM at idle
Hi,
I know I need to retune but does smaller pulley cause high RPM at idle before retune?
I used to have 4.10 pulley and now 3.40.
Thanks!
-Mike
***BTW, I got D1SC
Old 04-11-2009, 06:53 AM
Dumb Ass Vette Moderator
ls1290's Avatar
It definitely can. Think about it, the smaller pulley at the same RPM( even low like 900 ) will spin the blower faster than the larger one. At lower RPMs the smaller pulley should not make that much more than the large one. By any chance is the TB drilled?
Old 04-11-2009, 09:15 AM
MikeC5Vert's Avatar
That what I thought about smaller pulley spinning faster ...
Nope, no drilled hole in the TB.
Thanks,
-Mike
Old 04-11-2009, 09:21 AM
BlkHwk's Avatar
The air should be bypassing anyway. Shouldn't make a difference.
Old 04-11-2009, 09:39 AM
nuckifuts's Avatar
Exactly, and there is a little thing called an IAC motor. Smaller pulleys have no affect on idle.
Old 04-11-2009, 09:40 AM
MikeC5Vert's Avatar
Just checked and forgot to plug the TB wire
Thanks!
-Mike
Old 04-12-2009, 07:28 AM
ls1290's Avatar
Thanks!
-Mike
Those problems are nice to fix, but hard to admit
Quick Reply: Changing to smaller pulley, high RPM at idle
