Lingenfelter launch controller
hey fellas, i did a search earlier and found a thread that sounded like it would provide some promising answers but so far it hasent...im looking to get the lingenfelter launch controller with timing retard...is it possible to use it with out using the timing retard? thier installation instructions say for boost based apps, connect a GM 3 bar map sensor to the map sensor connector...see im running a MAF. will this be a problem? and for those not using the retard, how much boost are you building? Thanks
