Looking for single rear mount turbo will this work
I just picked up a 79 chevy malibu with a ls1 swap th350 3000 stall ford 9 inch 3.73 i'm want to do a rear mount turbo setup on it will this turbo work
GT45 TurboCharger
Wet Float Bearing
External Wastegate
Oil Cooled Center System
Compressor (4 3/16th's Inlet, 2.25 Intake Inlet, 3.25" Outlet Diameter, 69 Trim, .66 A/R)
Turbine (4" Outlet, T4 Flange, 3.5" V-Band downpipe Flange, 92 Trim, 1.05 A/R)
68.7 MM Inducer Compressor
97.8 MM Inducer Compressor
87.4 MM Exducer Turbine
77 MM Inducer Turbine
the motor is stock now and i plan to put a cam in it
do you run a intercooler on a rear mount turbo??? plan on running 10 psi
GT45 TurboCharger
Wet Float Bearing
External Wastegate
GT45 TurboCharger
Wet Float Bearing
External Wastegate
GT45 TurboCharger
Wet Float Bearing
External Wastegate
I am in the middle of putting together my DIY rear mount I ended up getting a T67. If you find you need a oil return pump I have a brand new spare I'm not going to use.
