p1sc install on lt1 i need some help please
Old 04-27-2009, 08:43 AM
baylove's Avatar
Default p1sc install on lt1 i need some help please
hey guys installed my p1sc on my lt1 yesterday the issue that im having now is with the pulleys i put the stock balancer/pulley on then the procharger spacer then the procharger pulley put all 3 bolts in with a washers got all 3 bolts reall tight and the stock pulley is loose are there suppose to be some spacers or something to get the stock balancer tight
Old 04-27-2009, 04:02 PM
dpinson's Avatar
i hate to ask but you do have the big bolt in the center correct?
if you do then maybe the whole stock pulley itself is not in far enough
wierd one man
Old 04-27-2009, 09:10 PM
green95vert's Avatar
1- Did the bolts they send you run out of threads?
2- Did the stock balancer/pulley's rubber piece slip and now its wobbly?
3-Did you tighten them down slowly together? When I put mine on I do them all hand tight, then go back and snug them, then tighten them up so it pulls itself on level and not all cockeyed.
Thats all I can think of.
Quick Reply: p1sc install on lt1 i need some help please
