sensors on victor jr.
Old 04-28-2009, 10:45 PM
turboescalade's Avatar
Default sensors on victor jr.
what sensors do keep when running a turbo 408 with a victor jr, with rails, a intake elbow and 90mm conversion tb on my 02 escalade... do i have to drill more holes to put in the map sensor? for those running a similar setup to mine, could you post pics and tell me what sensors you kept.. i'm keepin my truck on the street fyi.
Old 04-28-2009, 11:35 PM
TT-TECH Veteran
Inspector12's Avatar
I just ran a hose for the map sensor and T'd it off of the brake booster line basicly. And tied in my A/C control vacum line. I did away with the evap noid. GL!
Old 04-29-2009, 05:50 AM
WAHUSKER's Avatar
I ran a line out of the hole on the side of my Vic to a vacuum block & run everything off 1 reference.
Mark
Attached Thumbnails sensors on victor jr.-vic-jr-elbow-tb-fuel-rails-2.jpg   sensors on victor jr.-vacuum-block.jpg
Old 04-29-2009, 05:54 AM
Dumb Ass Vette Moderator
ls1290's Avatar
My MAP is in the side of the intake and then the boost boost and meth sensors are in side of the elbow.
Old 04-29-2009, 08:17 AM
cool, thanx alot guys
Old 04-29-2009, 10:33 PM
so what sensors did you keep and what ones did you go away with? did you switch to a 2 bar map sensor or just use the stock one that doesn't read into boost
Quick Reply: sensors on victor jr.
