Tubular manifolds what size are u running
I need to make a set of manifolds and am planning on using either schedule 5 or 10 tube to make up the manifolds. 1 1/2 will give you over 1 3/4 inner diameter and the 10 will be slightly undersized. Let me know what is better and what your running. Also what size should the crossover pipe be 2.5 or 3 inch. Turbo is a borgwarner s475 and I am shooting for north of 800hp.
Yes, 1.5" is plenty big, I use that size schedule 10, sch 5 would be to thin I would think, heat cycling = crack.. the inside of the pipe is bigger than the exhaust port just slightly.
The header flanges are lasered from the exact same size as the factory gasket. This header is the 1.5" sch 10
