Meth Kit
Does the current fuel system support what your current power level is? Meth injection will help as Bob said as you are adding more fuel, but by a different method. If you have not gotten the turbo set up together, then I would decide on how much power you are looking for, and build your fuel system around that first. Add meth injection into the loop afterwards, knowing that if you wanted you could support all your power on just racegas with no meth in the future if you wanted.
