Vic Jr vac line connections
Old 06-10-2009, 09:11 AM
koji777's Avatar
Default Vic Jr vac line connections
Can ne1 show me where/how they connected the factory vac lines on their Vic Jr setup. Posted in other forum ... no takers.
Any help appreciated
Old 06-10-2009, 04:24 PM
frcefed98's Avatar
Brake booster line:
3/8npt x -8an fitting, and one -8an 90deg barbed or push lok fitting. Thread NPT fitting into manifold runner, push the 90 deg fitting into the factory brake booster line all the way(a lil tough but will go all the way in) then connect the two.
Russell part numbers are:
660481 -8an x 3/8npt fitting
624170 -8an 90 deg Twist lok hose end
You can see the way I have it in the pics without the hose attached. The brake booster line fits perfectly, no shortening or lengthening required.
Side port on the manifold for the MAP sensor, just used the supplied barb fitting, and a short piece of vac line to connect the map sensor to the barb.
Hope this helps.
J
Old 06-10-2009, 07:18 PM
koji777's Avatar
Great pic... thanks for the info!!!
Old 06-10-2009, 09:42 PM
frcefed98's Avatar
no problem
Old 06-10-2009, 09:46 PM
mrr23's Avatar
same here. i "T"ed the MAP and AC vacuum line to the side port were you see the hard line.
Quick Reply: Vic Jr vac line connections
