Eating map sensors
Old 06-27-2009, 05:25 PM
rwb
rwb's Avatar
Default Eating map sensors
Any ideas why my car would be eating map sensors?? It is procharged but only sees 8.5 lbs of boost. If I put a new map sensor in it, it will run for about 10 minutes then it tells me high current on map sensor and dies. The measured voltage is always 12 to 13 volts so I am out of ideas. I have measured the wires with a vom and all was good. Anybody with any ideas??
Old 06-27-2009, 05:34 PM
CamaroSS19's Avatar
Im not 100% but pretty sure it should be reading 5v you may have a bad cpu
Old 06-27-2009, 06:32 PM
rwb
rwb's Avatar
It has 12v in and 5v out to the computer.
Old 06-27-2009, 06:37 PM
LS1Tech Sponsor
hellbents10's Avatar
Should only have 5v in and then 0-5 for signal back to the computer. You either have a short to batt or a bad computer.
Old 06-27-2009, 07:44 PM
rwb
rwb's Avatar
I went and remeasured it and it is 5v in. Sorry my bad.
Quick Reply: Eating map sensors
