Fuel drops 5 psi
Old 06-29-2009, 01:21 PM
garrett3's Avatar
Default Fuel drops 5 psi
It's a LS1 with magnacharger at 7lbs, stock bottom end and racetronix fuel system. At full throttle the fuel pressure drops from 60 to 55. Is this a safe drop?
Old 06-29-2009, 01:49 PM
black98ws6ta's Avatar
I'd say that's fine.
Old 06-29-2009, 04:17 PM
dschmittie1's Avatar
As long as your car was tuned with the Fuel pressure drop and your A/F is good then it is ok. But if your car was tuned with fuel pressure staying constant or climbing and now it is dropping then you might have a problem
Old 07-01-2009, 02:34 AM
SStolen's Avatar
Exactly.
You should really go ahead and invest $200 for a wideband air/fuel. AEM is cheap and one of the most accurate in tests.
Old 07-01-2009, 09:27 AM
garrett3's Avatar
Sounds good, thanks.
Quick Reply: Fuel drops 5 psi
