gtm tc78 vs t78 vs precision 78gts
Old 07-01-2009, 12:44 AM
turbotaws6's Avatar
Default gtm tc78 vs t78 vs precision 78gts
I was just wondering how they 3 turbos would stack up against each? Is there much difference? Which would make the most power? How about spooling up? Im stuck between these 3 & wondering if theres much difference? thanks for your help
Old 07-01-2009, 03:26 AM
black98ws6ta's Avatar
What t76 are you refering to? I believe the 78 gts will make the most power, the tc76 will probably spool fastest.
Old 07-01-2009, 03:39 AM
turbotaws6's Avatar
the turbonetics t78. is the tc78 with the gtm race cover better than a regular t78?
Old 08-27-2009, 08:25 AM
omore001's Avatar
Ressurecting this thread, I would also like to know how the TC78 stacks up against a regular T-78 (both Turbonetics). For sure the 60 series housing on the TC holds back over 100 hp compared to the regular cover on the T-78, but how would the TC78 w/race cover compare against a regular T-78? Would they make about the same power with quicker spool on the TC?
Old 08-27-2009, 08:58 AM
LS1TECH Sponsor
DrTurbo's Avatar
The GTM-78 will make more power then a T series unit. The GTM is simply the Super T series unit without the ball bearing and more affordable to the masses.
Old 08-27-2009, 09:27 AM
omore001's Avatar
Great info, thanks again DrTurbo.
Quick Reply: gtm tc78 vs t78 vs precision 78gts
