have a few boost questions.
Well I was planning on doing a na/nitrous build on my 383 ls1 impala project. And I have some t62 garrets that I want to put into use. And I was wondering about what boost or hp level are the 6th bolts needed? Those turbos should boost about 1100hp at the crank. And that's what hp I would like to be at. also my ls1 block is a 3.9 bore is that safe to boost? And I have a iron 6.0 block here also should I use that instead? I have an eagle forged crank and rods. I'm sure those will do. Also I have an ms4 cam with a 112 lsa should I change to a wider lsa? Or just get a custom spec cam? Thanks for any useful imput.
