Boost leak victims
Old 07-13-2009, 02:04 AM
Slow5.0.'s Avatar
Default Boost leak victims (turbo)
I recently found a good boost leak on my car and was wondering who all here has found some boost leaks (big or small) and how much did it effect your 1/4 mile times/mph? How big/small was your boost leak? Just wondering if I am going to pick up some power with finding this when I go back to the track. (still gotta wait a couple days )
Old 07-13-2009, 04:58 PM
BLOWNBLUEZ06's Avatar
I can't tell you how much it affected my 1/4 mi times, but I had a boost leak in my bypass valve. It was barely stuck open (about .100") and lost the o-ring. I was losing a little over 4psi boost. I didn't know I was losing boost until I started logging the car with a 2-bar tune. I damn sure knew when the boost came back though. Funny how you get used to a car and don't really know it's running less than perfect until you see a trap time/speed or log it.
Old 07-13-2009, 07:11 PM
conan's Avatar
Went to the dyno about a month ago and switched to a SD tune. The pipe I put in place of the MAF was leakig and I was at 6#s of boost, around 430 hp. Put the maf back in place and went to 11#'s around 490-500 hp on the next pull.
Old 07-18-2009, 02:08 AM
Slow5.0.'s Avatar
I was meaning turbo guys sorry.
