Question for you forced induction guys
Old 07-23-2009, 10:44 PM
space_monki's Avatar
Default Question for you forced induction guys
how well would this kit work with a blow through supercharger?
Holley 950-24S - Holley Commander 950 TBI Kits
Brand: Holley
Manufacturer's Part Number: 950-24s
Part Type: Fuel Injection Systems
Product Line: Holley Commander 950 TBI Kits
Summit Racing Part Number: HLY-950-24S
EGR: No
Injection Style: Throttle body
Metering Style: Speed density
Intake Manifold Included: No
Engine Block Style: Stock/OEM standard deck
Fuel Rails Included: No
Throttle Body Included: Yes
Throttle Body Mounting Flange: 4-barrel square bore
Venturi Quantity: 4
Airflow Rate (cfm): 900 cfm
Throttle Body Material: Cast aluminum
Throttle Body Finish: Natural
Injectors Included: Yes
Calibration Module Included: No
ECM Included: Yes
Wiring Harness Included: Yes
Oxygen Sensor Included: Yes
Fuel Pump Included: Yes
Fuel Pressure Regulator Included: Yes
Distributor Included: No
MAP Sensor Included: Yes
IAT Sensor Included: Yes
TPS Sensor Included: Yes
IAC Motor Included: Yes
Quantity Sold as a kit.
Notes:
Laptop computer required for calibration.
Old 07-23-2009, 11:02 PM
YSILT1's Avatar
You will never get enough fuel using that. I would use one of there port fuel style kits instead. The Accel DFI kits are way better and the ECM can be configured for boost and a wideband.
Old 07-23-2009, 11:11 PM
cool thanks
