any chance of boosting a 13.5:1 SBC on alky?
would it be possible to boost a 377SBC with 13.5:1 comp on alky? cars setup for racegas right now but my dad really likes turbos and would rather not sell his hand ported brodix track 1's only thing i can think of is running alky to keep it cool any suggestions?
yes you can run that compression with boost on methanol,but you shouldn't do it with an engine built for n/a.The pistons, pins and rods need to be able to take the abuse.you need a piston and pin designed for the power and an aluminum rod to soften the beating on the crankshaft.Otherwise you're going to end up with alot of broken parts.
