Going to the drag strip later today. Shift question...
Old 09-16-2009, 12:29 PM
mightyquickz28's Avatar
Default Going to the drag strip later today. Shift question...
Is there any advantage to short shifting 1st gear on a Turbo car?
My setup is all done by 6,200 rpm so I was wondering if there's any concensus on doing the 1st - 2nd shift at say 5,600rpm instead of winding her all the way to 6,200? In theory, this seems like it would keep the turbo under load for a greater length of the 1/4 mile. Am I off base here?
Old 09-16-2009, 12:58 PM
Super Slow SS's Avatar
Experiment and let the masses know, the theory is good but a few things come into consideration.
First will it make you have to shift and extra time by the end of the quarter?
Second what gear ratio and weight/load are you running and will shifting this soon make you come into the next gear below optimal RPM range.
Third what does your turbo spool at and what RPM range is most beneficial torque to horse power ratio.
There are more, but this should be some food for thought.
Old 09-16-2009, 01:07 PM
pwrtrip75's Avatar
Only if you have traction problems. I would imagine you make more HP as the RPMs increase, shifting early is just wasting....unless you need to regulate it due to bad traction.
Old 09-16-2009, 01:27 PM
BadgeZ28's Avatar
You are going to be busy with that rear gear ratio. Busy meaning first to second will be quick. I would probably set the shift point lower for that reason only.
Old 09-16-2009, 02:02 PM
Tiago's Avatar
if its hooking, hold it in first, if it start spinning the short shift maybe the key.
Old 09-16-2009, 03:43 PM
Restricted User
98Z28CobraKiller's Avatar
I have always been told that you want to shift 3-5 hundred RPM past peak HP.
Old 09-16-2009, 03:55 PM
ninetres's Avatar
I have been told by experts to keep the car in the peak tq range as long as possible....which is lower than redline on our turbo cars. Here is what I do:
1-2 shift light comes on at 6400 (trans probably shifts at ~6700 by the time I pull the lever). I try to shift as soon as I see it light up.
2-3 shift I always grab right on time as the RPMS are not climbing as fast as 1st gear. SOmetimes I shift a tad early just to take advantage of the full 1:1 gear ratio of 3rd.
Old 09-16-2009, 08:17 PM
Well... Only got to make the one pass tonight. The Clutch got kind of stuck after the burnout when I was going to do the second pass. It was weird. THe pedal felt fine but the clutch wouldn't disengage so I could put it in gear. The burnout went fine and the car hopped right up to the staging lights. I clutched it so I could tickle the car into the staging beams but it was acting as if I'd never pressed the clutch pedal. I had to be pushed back off the track. Once there, with the motor off, I put it in reverse and cranked it. It bumped a couple of times, then caught and I backed it into the pits. After that, the clutch made a few 'inappropriate' sounds like squeals but returned to functional status. WTH? Anyway, on the one pass...
I'd ran out of time and didn't get to unbolt the front sway bar. I also didn't get to swap out the stock LCA for my BMR. This caused the 245x50x16 Nitto DR's to do some wheel hopping. I *did* the short 1st to 2nd shift and 2nd gear felt flat wonderful, then I shifted to 3rd and 4th normally but the acceleration felt a bit flat so I let off before the end of the track.
Result:
Reaction: 0.135
60 foot: 2.017
330 ft mark: 5.417
660: 7.941
MPH1: 108.52
1000 ft. Mark: 10.041
1320 ft mark: 11.876
MPH2: 119.86
The time slip is so grainy it's hard to see and I'll post it in a minute. The Cobra beside me thought he was going to hand me my head. I think once I got into 2nd gear, he had a rethink moment. Looks like he let off and coasted...
Here's the pass. Please forgive my wife's shaky camera work (Think Blair Witch), lol..
Old 09-16-2009, 09:07 PM
BadgeZ28's Avatar
Sorry to hear about the clutch. Looks like a high 10 will be there with a good clutch, and a better short time.
Old 09-16-2009, 09:16 PM
Peak torque on the dyno occurred at 4,650 RPM, Peak HP was at 6,000RPM.
Old 09-16-2009, 09:30 PM
Black_98Z's Avatar
Sounds like your clutch line is getting hot. Check to see how close your exhaust is to it. Might need to be insulated.
Old 09-16-2009, 09:37 PM
Interesting suggestion. I"ll have a look tomorrow.
Thanks!
Old 09-16-2009, 09:48 PM
LS1TECH Sponsor
DrTurbo's Avatar
Result:
Reaction: 0.135
60 foot: 2.017
330 ft mark: 5.417
660: 7.941
MPH1: 108.52
MPH2: 119.86
What clutch are you running?
Old 09-16-2009, 09:54 PM
Tiago's Avatar
what DA was this at?
nice run
Old 09-16-2009, 10:20 PM
The environmental variables according to the timeslip;
BAR: 29.63
Temp: 60.8F
Hum: 84%
CALT: 911
Wind MPH: 0
nice run
Old 09-16-2009, 10:21 PM
SPEC Stage 4
SPEC Billet Steel Flywheel
Grainy Timeslip:
Old 09-16-2009, 11:17 PM
RealQuick's Avatar
Like i said in the other thread, most manual cars gain 28-30mph in the 2nd half, so your 108mph 1/8th shows some high 130's potential as is. that smoke that came out once you hit 3rd gear isn't a good sign though.
Quick Reply: Going to the drag strip later today. Shift question...
