ATI ProCharger GTO Overdrive Pulley for Fluidampr Available at EPP
ProCharger supplied pulley is on the left, our new overdrive pulley is on the right.
http://www.exoticperformanceplus.com...html?item=1938
This is a one inch larger crank pulley for use with the Fluidampr 740102 balancer. This larger crank pulley is designed to be used with the ProCharger GTO kit, and will enable higher boost levels without resorting to a small blower pulley. This will allow better belt wrap resulting in less belt slippage. This pulley will work with the P-1SC, D-1SC and the F series of blowers. Bob
