Do I need a clean air source in my catch can system.. Pics inside
Old 09-26-2009, 06:34 PM
vipvegas's Avatar
Default Do I need a clean air source in my catch can system.. Pics inside
Here is my layout. Wondering do I have to add a breather or anything for a clean air source or is vacuum good enough. Here is the layout all other ports on valve covers will be blocked besides the one you see used. Thanks
Old 09-28-2009, 12:11 AM
vipvegas's Avatar
anyone??
Old 09-28-2009, 03:34 PM
vipvegas's Avatar
no one knows the answer? Any help would be appreciated.
Old 09-28-2009, 04:35 PM
Monello's Avatar
I would just cap the outlet next to the intake opening. Rest of it looks like mine, but I do have a breather on the oil cap. Been thinking about removing it, since it stinks of oil when im sitting at a stop light.
Old 09-28-2009, 05:15 PM
vipvegas's Avatar
Ive got the layout figured out as long as it doesnt require a clean air source such as breather. Noone seems to know on this one.
Old 10-22-2009, 06:30 PM
vipvegas's Avatar
TTT can anyone help on this one??
Old 10-22-2009, 09:58 PM
Aster's Avatar
It is my understanding that you need some form of a fresh air source for the pcv.
I got a small filter from the parts store and ran a hose to the front passanger valve cover for it. I don't get any smell out of it, but then I am pulling 16 - 18inches of vacuum at idle. Other than that my setup looks similar to your drawing.
Old 10-22-2009, 11:39 PM
vipvegas's Avatar
but wouldnt you have to vent both the passenger and drivers side valve cover??
Old 10-23-2009, 02:40 PM
vipvegas's Avatar
This is the first time in 3 years I think no one had answered with appropriate fix. Interesting.
Old 10-23-2009, 03:16 PM
SilverSS's Avatar
Yes, you will need delete one of the hoses from the catch can and add a filter to that hose and allow fresh air in. The way you have it now there will be too much vacuum in the crank case and you will have issues with valve seals and gaskets and the oil pump will hate you.
Fresh air in will keep your oil happy. Put an adjustable flow regulator on the fresh air hose. This will allow you to control how much vacuum is in the crank case. With the oil fill cap off and the car idling, cover the oil fill tube with your hand. A small amount of vacuum felt is ideal.
This system work best with an oil fill cap that has a check valve and a breather filter on top. The cap will allow excess pressure to escape the crank case during boost but not let air in during vacuum.
Old 10-23-2009, 04:50 PM
vipvegas's Avatar
I dont see where the factory setup draws fresh air into the crankcase. I also thought the vacuum is a good this. What if I ran a line off driverside valve cover to a hose with filter on the end would that work? But then wouldnt I have to do the same for the passenger? Do not have room to delete line on catch can.
I mean with the LS2 valley cover where on the Ls2 does the valley cover get fresh air in the factory setup with the vented valley
Old 10-23-2009, 08:31 PM
SilverSS's Avatar
Not sure where the factory fresh air comes from on an LS2 but on an LS1 it comes off the throttle-body. If you don't cap it there you end up boosting the crankcase.
Yes, run the line off the driver side valve cover with a filter on the end. The passenger line will go to the catch can along with the valley cover. The single fresh air line will be plenty. Unless your check valves are not very free flowing, it is best to use a flow regulator on the fresh air line to control the rate of flow into your intake. Vacuum is good but not too much.
Old 10-23-2009, 08:43 PM
vipvegas's Avatar
just ordered speedinc. oil cap breather with check valve installed. Also couldnt you run a crossover line from valve cover to valve cover to equalize the fresh air flow?
Old 10-23-2009, 08:53 PM
SilverSS's Avatar
yes you can
Old 10-23-2009, 09:24 PM
LS6427's Avatar
If I were you:
I would cap the valley cover port.
Cap the passenger valve cover breather port.
Suck crankcase gases from the drivers side valve cover.
Allow fresh air to be pulled in from that oil cap breather you ordered.
Cap BOTH vacuum ports on the intake and the TB, of course.
Its better to pull crankcase air from the valve cover than the valley cover port because I think too much crankcase oil mist gets pulled out from that valley cover port.
All you need is one way for air to go in (oil fill cap breather) and crankcase gases get pulled from the drivers side valve cover. This will have fresh air flowing across the entire engine crankcase.
With a PCV valve in-line with the check valve, you'll be good to go.
Thats what I would do.
Attached Thumbnails Do I need a clean air source in my catch can system.. Pics inside-img128.3.jpg
Old 10-24-2009, 12:19 AM
SilverSS's Avatar
His oil cap breather will be a one way flow only hence the check valve. It will only allow pressure in the crank case to escape under boost but will not allow air in. Without a check valve type breather, you will never maintain vacuum in the crank case during normal driving. Just a lot of air movement. Too much ummetered air if you are still on a maf. If SD, you may run into idle issues and you will have to tune it out.
I've played with this stuff for years with trial and error and is seems that a small amount of vacuum controlled by an adjustable flow control valve to the crank case is the best. There seems to be no right way and too many ways to do it. If it works, use it. It has worked this way the best for me so far.
Old 10-24-2009, 12:29 AM
kenp's Avatar
You have it right IMO. A simple breather just negates the PCV and vents the engine to atmosphere.
Old 11-02-2009, 01:04 PM
kenp's Avatar
I called Speedinc and they told me there is not a check valve in their oil fill breather. It's just open to the atmosphere.
Old 11-02-2009, 02:15 PM
SilverSS's Avatar
That sucks. I know you can buy one, I've seen them for sale. I made my own using one of the check valves from my "AIR" system. Mounted the valve to the oil fill cap with a small K&N filter on top. Works great.
Old 11-02-2009, 02:56 PM
Camaro01SS4life's Avatar
Couldn't you block off all the fittings and run catch/breather cans off of each valve cover?..
Kev
Quick Reply: Do I need a clean air source in my catch can system.. Pics inside
