D1-SC strange noise...
Old 10-06-2009, 01:36 PM
'Trust''s Avatar
Default D1-SC strange noise...
My blower has been making a weird noise lately. When I start the car it whines, but intermittently, almost like a squeaky pulley. When it warms up it sounds fine, any ideas of what this could be? I talked to ProCharger about having to have significant tension on the blower to stop slip and they said the bearings can take it no problem, but I'm a little concerned, thoughts?
Old 10-06-2009, 01:43 PM
El_Diablo's Avatar
You've been over-driving it as well haven't you?
Take it off and open it up ASAP. I saw this recently in a post somewhere on another forum and it was the bearings. Catch it before it's too damaged.
Old 10-06-2009, 02:02 PM
'Trust''s Avatar
Nah, it is spinning at 59,000, max is 62,000.
Old 10-06-2009, 02:10 PM
'Trust''s Avatar
Hmm, well just talked to ProCharger, they said if it's a bearing, it will be pretty much gone quickly. This has been going on for a month and has been to the track twice and probably had 10-20 WOT pulls on the dyno/street. They suggested an idler pulley bearing, pulling that off tonight and checking it out, could be possible.
Chalk one worthless thread up for me.
Old 10-06-2009, 02:44 PM
BIG_MIKE2005's Avatar
Not worthless if you get it figured out & others know what to listen/watch for on theirs
Old 10-06-2009, 02:46 PM
LS1RedZ's Avatar
Is it like a chirp sound?
Old 10-06-2009, 03:17 PM
03supercobra's Avatar
Sometimes you can spray a little WD40 on the different idlers when you first start it up, and thatll let you know which one is squeaking.
Old 10-06-2009, 04:08 PM
01 Red WS6's Avatar
If you had the F1A this wouldn't be a problem
Old 10-06-2009, 04:14 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
+1
Old 10-06-2009, 04:24 PM
'Trust''s Avatar
Basically yea.
So true!
Old 10-06-2009, 04:46 PM
LS1RedZ's Avatar
Hmm I have been hearing the same thing. Damn it!
Old 10-06-2009, 04:53 PM
'Trust''s Avatar
I'll pull my idler off tonight to see if thats it and let you know.
Old 10-06-2009, 05:52 PM
ZLEEPER's Avatar
My F1A does it on decel sometimes... Brand new set up. I know this doesn't help, but you are not alone in chasing the mysterious squeak.
Old 10-06-2009, 06:17 PM
kp
kp's Avatar
The idler bearings go bad all the time, especially when you tension the crap out of the belt.
Old 10-06-2009, 07:48 PM
'Trust''s Avatar
Well the idler seems a little stiff, if I spun it with my finger it will spin about 1 - 1 1/2 revolutions. Doesn't seem right to me, thoughts? Also, I did found out that wasn't the sole squeak. Took the blower off and started the car, same thing, I have a culprit somewhere.
Old 10-06-2009, 08:00 PM
kp
kp's Avatar
They are sealed bearings so they wont just free spin, if it feels gritty or rough then they are bad. They are just GM A/C compressor bearings and easy to get and change.
Lot of other pulleys to squeak, take the main belt off and try it for a bit to make sure its from the front, it wont hurt to run it without the belt for a minute or so if the engine is cool.
Old 10-06-2009, 08:12 PM
conan's Avatar
Do you still have the A/C? If so spin the clutch with the belt off. Did you spin the spring tensioner pully for the serpentine belt?
Old 10-06-2009, 09:06 PM
'Trust''s Avatar
Yea, I thought about taking the serpentine belt off, and a/c belt off to see and leave the blower hooked up. I'll give that a shot.
Old 10-06-2009, 10:19 PM
laughatrice's Avatar
Interesting I've got an F1A (fbody) and the idler pulley has been acting up every since I changed the belt last week. It ate the new belt at the track swaped it again with less tension and made a 3 passes at the track 4 WOT pulls at the dyno and then the idler failed. I haven't seen it yet but I from what I heard it was fairly dramatic and actually stalled the engine smoke and rubber everywhere.
I'm assuming the idler pulley seized up I had been tightening the **** out of it lately. I was told the same thing as you regarding tension worst you'll do is f the belt up unless you happen to bend the idler pulley . I ordered a whole new idler pulley assembly from procharger plus one of the goodyear belts from summit (not suppose to stretch as much). I believe I caused this when I tightened the belt the weak link is the idler pulley I think it gets bent.
Old 10-07-2009, 04:48 AM
EPP
EPP's Avatar
FYI. I sell the idler pulley with the bearing on my website at this link. http://www.exoticperformanceplus.com...html?item=1497 Bob
Quick Reply: D1-SC strange noise...
