10 rib pulleys
Old 10-06-2009, 07:48 PM
02' hawk's Avatar
Default 10 rib pulleys
Is there a 10 rib pulley seteup for the ls1? I'm needing a crank & procharger F1C pulley with a 10 rib. Also a wider tensioner for the larger belt.
Old 10-07-2009, 02:35 AM
Jontall's Avatar
http://www.atiracing.com/products/da...harger.kit.htm
Old 10-07-2009, 04:39 AM
EPP
EPP's Avatar
The wider 10 rib assembly may not get rid of the belt slippage for you. Our cog drive kit will though. http://www.exoticperformanceplus.com...html?item=1749 Bob
