need help from the aps turbo guys using a manual boost controller
Old 10-09-2009, 12:41 PM
flyinbluess's Avatar
Default need help from the aps turbo guys using a manual boost controller
Bought a turbonetics manual boost controller....... Wanna verify there install directions. Its a 4 port reg. The 2 sides get plugged.... Then one port goes to both top side ports on the wastegates and the other port on the regulator .... Gets put in a T fitting between the side port vaccum connector on the wastegate and the fitting in the turbo ?? Does this sound correct ? Anyone have pics of there install ? Thanks
Quick Reply: need help from the aps turbo guys using a manual boost controller
