need help!!!
need help!!!
hey guys i really would like some help on deciding what i would need to buy or also get in order to go FI on my 02 t/a! this is all i have done to my car:
TR 224/224 .563/.563 112lsa
hardened TR pushrods
tit. retainers
918 springs
LS1 Edit
double roller
TCI 3,500 2.5 stall
160* stat
Pacesetter LTs coated
Pacesetter ory pipe
SLP loudmouth w/3.5 tips
p/p stock TB
SLP lid
QA1 12 ways (4)w/ 325 springs
UMI subframe connectors
UMI panhard adj.
UMI Lca's non adj.
UMI strut tower brace
MIDWEST fabbed 9"; strange alum center,drain,braced, detroit tru trac,31 spline axles moser,1/2" studs,tcs/abs,lca relocates,motive 3.89
Strange chromoly driveshaft
MIDWEST tourque arm/chromoly w/ shortened tunnel mount
3" 12mm studs for front
TCI line lock
B&M trans cooler
thanks
tit. retainers
918 springs
LS1 Edit
double roller
TCI 3,500 2.5 stall
160* stat
Pacesetter ory pipe
p/p stock TB
SLP lid
UMI panhard adj.
UMI Lca's non adj.
TCI line lock
B&M trans cooler
thanks
