MSD boost a pump voltage settings
I just installed the MSD 2351 Boost a Pump. My car under boost fuel pressure would drop from 60 to around 52 prior to the BAP. With the BAP set at 18.5 volts my fp is now at around 56. How much voltage can a stock fuel pump handle from a BAP? Should I go up to 19 to 19.5 volts to get closer to my normal cruise/idle fuel pressure of 60?
