upgrading ?
Old 11-21-2009, 12:30 AM
1999 SS's Avatar
Default upgrading ?
i have a stock cube ls1 with all the bolt ons and heads and cam plus ewp, fast 90/90 and over the winter i plan on swapping out the f14 cam (232 234 .595 .598) for a more blower friendly cam, a set of 317's and a p1sc-1. the injectors i have on there now are 36 lbhr and i was planning on running between 8 to 10 psi. do i have enough injector to feed the motor.
its a stock bottom end motor and i will be up grading the rod bolts at the same time and i want this thing to make at least 550rwp +, do you guys have any suggestions on the cam?
Old 11-21-2009, 07:46 PM
1999 SS's Avatar
i would really appreciate any help you guys could give me.
Old 11-22-2009, 09:27 PM
1999 SS's Avatar
t t t
Old 11-22-2009, 09:51 PM
dlandsvZ28's Avatar
Maybe Bob at EPP will chime in but I think at 80 percent duty cycle and at 550 rwhp you will need more than 42's and 60 or less so might as well install 60's.
60's seem to be the most common size to use in the over 500 and less than 600 rwhp range giving you some room to go down one pulley size, make some addtional HP and still have enough injector left.
You will need a fuel pump too. The stock pump won't handle the addtional volume unless you already have the Racetronix Kit.
Old 11-23-2009, 05:10 AM
EPP
EPP's Avatar
I agree, 60# injectors and I'd add a Walbro fuel pump. Here is a link to our blower cam, which has proven itself to add a lot of power while being boost friendly. http://www.exoticperformanceplus.com....html?item=679 Bob
Old 11-23-2009, 11:03 PM
1999 SS's Avatar
thanks for the input guys.
i like the sound of that cam a lot.
i already have a Walbro in tank.
is there a way to have my current injectors upgraded?
Old 11-24-2009, 05:16 AM
EPP
EPP's Avatar
Your best bet is to sell them and buy larger injectors. Bob
