317 Head Gasket?
Old 12-04-2009, 06:21 PM
2002RamAir's Avatar
Default 317 Head Gasket?
I have searched and searched and still come up with different answers... Im putting 317 onto my 02 ls1 block to drop compression for turbo. I plan on running the gm gaskets, but what size do I need the 5.7/6.0 or the 6.0/6.2??? All I get from searching is 6.0 gaskets... Any help or part numbers would be amazing!!! Thanks
Old 12-04-2009, 06:55 PM
Tally TransAm's Avatar
i used these to put them on my 99 block. should be the same as yours
Old 12-05-2009, 09:57 AM
taws6m6's Avatar
I went with a set of ls9 gaskets
Old 12-05-2009, 11:03 AM
conan's Avatar
You want 6.0L gaskets, they have to clear the bigger combustion chamber of the head. These are the cometic gaskets I'm using http://www.texas-speed.com/shop/item...d=603&catid=36 @ .051 thick.
Here's the GM MLS gaskets. http://www.texas-speed.com/shop/item...d=880&catid=36
