Need Turbo Information
Old 12-08-2009, 06:33 PM
elevator_idiot's Avatar
Default Need Turbo Information
I am able to possibly get a Holset HX50 and H2D Turbo off a big diesel generator. The exhaust housing is enormous. What stock housings are available (cummins?) and or where to buy new exhaust housing. I would be putting this on a 5.3L truck motor for a street car so something sized for that motor. Any input, information, and links would be appreciated.
Thanks!!!
Old 12-08-2009, 07:36 PM
OUTLAWZ RACING's Avatar
Im not sure about that turbo u have but a mpt70 would go nice for that 5.3 or a tc 76 if your budget allows. There are some borg waner units also that fit a tight budget. Check out forceinductions.com
Old 12-09-2009, 10:14 PM
anyone else have any info on Holset turbos?
Old 12-10-2009, 12:06 AM
ninety4three4's Avatar
Trying to contact Holset directly would probably work the best. Either that or I can try and find something over on the cummins forum. The best thing to do would be to pull the housings off and measure the wheels with a caliper to give you an idea of what you are looking at. For instance a gt4202 (comprable to a T76) has a compressor wheel with a 74 MM inducer 102 MM exducer and an 82 MM Backwheel... Hope that helps some
Quick Reply: Need Turbo Information
