3 inch downpipes with stock k member and truck manifolds
has anyone been ab le to run a 3 inch-down pipe on the driver side with the stock k-member? I have a 3 inch y-pipe with dual cutouts that i would love to retain and want to run a down pipe from each turbos....and in trying to avoid paying for a new kmember...
you will need solid mounts. i had 3 inch down pipe with spohn solid mounts and there was not much clearance i had to make a slight dent in the down pipe for the steering knuckle
