Ok to extend wideband wires?
Old 12-28-2009, 02:24 PM
XtremeDime's Avatar
Default Ok to extend wideband wires?
Is it ok to extend the wiring from the sensor to the box beyond factory wiring? I dont want to mess up signal transfer by adding connectors and lengths of wire. Thanks!
Old 12-28-2009, 02:32 PM
tdt
tdt's Avatar
Default wide band wire extension
No it won't disrupt the signal at all just use the same gauge wire and a good connector and you will be good to go. I had to do it on a previous build and it worked fine.
Old 12-28-2009, 02:54 PM
ModularTurbo's Avatar
what he said I've done it myself it won't hurt anything if its done right
Old 12-28-2009, 03:33 PM
SS2win's Avatar
depending on your setup, you might be able to repin the secondary sensor wiring and save the splicing.
