turbine position rotation question
i just received my gt67 to upgrade my worn 60-1 on my trucks STS system. the problem is my 60-1 has the exhaust inlet in the upward position and the outlet to the intake in the downward position. i received my gt67 which has both the outlet and the inlet in the same position. i am asking this question before doing anything. can i just unscrew the bolts and turn either the turbine or the compressor about 180 degrees to the desired position of my downpipe? im thinking its something simple since its just a matter of turning it and screwing it again however i was advised by a friend to not touch a bolt on the turbocharger because that will ruin it.
im not in the US so shipping it and waiting for another one is a pain.
What kind of HP did you get from your 60-1? Track times? Was it a T4? I have a butt mount and wondered how a real STS performed.
Thanks
Jack
my bad man, im in the same position as you, before i put my turbo on im going to have to rotate both hot and cold side housings of my 60 series T-netics. I was asking the question to anybody that reads this thread and knows the answer.
