Higher power and torque and stock rubber engine mounts.?
I went to poly engine mounts with my aps as supplied with my kit. Clearances are pretty tight on passenger side and also maybe with the torque and hp plan on putting out with the upgraded turbos between 800 and 1000rwhp then wonder if stock rubber mounts would rip up. I am considering going back to stock mounts with maybe a torque strap type of idea. I think am getting still a bit much vibration from the poly mounts. So will the stockers survive at higher hp and torque levels especially if use a torque strap type of setup?
