Big thanks to josh@kyturbo!!!
Guys Josh is a great guy!! when he found out i need a block he helped me out!! and now ill be up and running in no time!!!1
Thanks again buddy and it was great meeting/talking with you tonight!!!
If you have not worked with Josh you are missing out he is top notch.
no i drove the thing down to the shoot out last year(7 hours) and from what i can see the transmission bell housing bolts backed. While on my last pass on the 2-3 shift the trans shifted a little bit and broke the drive shaft got into the starter and broke of the starter and took part od the block with it.which at 6800 rpm cant cause a lot of bad things! LOL But on a good note with all that going on the car still went 10.51
