LS2 Turbo build
LS2 Turbo build
Currently working on a sts turbo ls2. The motor is in the machine shop awaiting assembly. Im waiting on a backordered part for three months, but it's finally here. So far I have a Stock LS2 block Aluminum, Stock crank, eagle h-beam rods, mahle forged dished -16cc pistons, upgraded pins, arp rod bolts, Dm Engine girdle and arp studs, ported 317 heads, comp 224/224 cam, comp dual springs, Ls9 piston oil squirters, ls9 head gaskets.
tuner say motor will push water past 15 psi, what can else can i do while the motor is apart to ensure maximum durability and longevity at 20-25 psi, street car daily driver.
