wastegate hookup and fpr line
im going to be running a tial 44mm wastegate. im going to be running about 6 pounds to start. so i figured id run the 6 lb spring. so do i still need to hook up the vacume lines or will the spring just open on its own at 6psi?
also while reading the sticky, for the fuel pressure regulator it suggests to hook it up before the tb. so should i just weld a nipple on the intake pipe and run a line from that?
