Oil change on a rear mount setup---
What are your guys' procedures for doing an oil change with a rear mount turbo. do you do any thing special like take all lines off and drain? Also what oil are yous using conventional or synthetic?
I don't do anything different than a normal oil change. The residual oil in the return line isn't enough to worry about. And if you do want to worry about it, don't remove anything, just cycle the key to 'on/run' a few times which will kick on the oil pump without cranking over the motor. This will pretty much clear the return line. I run a synthetic 10w-30.
sweet, that's what i was planning on doing, is just doing a normal oil change and then popping off the return line and letting it pump until clean oil comes out. and i still have to get that check valve installed!
