Procharged Silverado 4.8.. Part 2. Replacing the things i cheaped on.
Old 05-13-2010, 08:22 PM
Ericmck2000's Avatar
Default Anybody want some boat anchors?
Welcome to project "Shoot a pickup into the 10s"
Also, here are the specs of the build:
Engine:
390ci. Built by AES.
10.5:1
Controlled by Holly Dominator
Transmission:
TCI 6x, 1200hp version, (With a 20year warranty!)
Controlled by Fast TCU.
Fuel System:
(TBD)
Planning on Holley Fuel System.
Methanol:
Snow Stage 3 controlled by Holley ECU.
Power Adder:
Strongly considering doing a twin-ebay turbo setup.
WAS planning on a PT88 or so, but, I hear more bad things about precision then I do ebay turbos. 600$ vs 2200$
(Was supercharged,sold the p1sc to a member on here)
Skip to page 3.
Old 05-13-2010, 09:25 PM
elias_799's Avatar
pics not working ?
Old 05-14-2010, 06:31 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
You'll have to let us know how it turns out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-14-2010, 08:56 AM
Will get back with you after dyno time by next wednesday.
Old 05-14-2010, 09:02 PM
Well, I installed it. But..... the belt was too small...... i gotta go pick up a 3 or 4 inch longer belt tommorow.
new pictures uploaded to truck.xtremeownage.com.... bonus points if you can spot my blood all over everything.....
Old 05-25-2010, 02:50 PM
Truck is on dyno now.
Just called them, its pushing around 370ish at the wheels, they estimate a little over 500 at the crank.
Not gonna be able to pick it up today, I had a 02 senser die.
Exhaust is done. Headers going into true duel 2.5 pipes with 40 series dumping before the axles.
Old 05-27-2010, 09:40 AM
Dyno sheets and graph up.
http://truck.xtremeownage.com/
Need a bigger fuel pump. Fuel pressure started dropping around 11 lbs of boost.
Old 05-27-2010, 10:21 AM
Frost's Avatar
That thing went lean before 6K and you guys stayed in it! It gets lean about 5700 and at 6250 at peak boost it's at 13.0 !! I would think your best bet would be to let off the throttle by 12.0:1
What pump are you running?
Old 05-27-2010, 10:30 AM
Factory. We just set the limiter to 5.6, and its shifting at 55. Ill replace that another day.
Old 05-27-2010, 06:21 PM
Frost's Avatar
Nice, that works
Old 05-29-2010, 06:31 AM
LS1Tech Sponsor
You're going to have a nice running truck! Bob
__________________
Old 05-29-2010, 09:01 AM
too bad the tranny died last night..... no second gear
Old 05-30-2010, 12:45 PM
LS1Tech Sponsor
That's too bad, a well built 4L60E can handle the power you are making. We've used RPM Transmissions 4L60E's at up to 700 rwhp without any problems. Bob
__________________
Old 05-30-2010, 01:01 PM
Well.... Would you recommend a built 4l80e or a built 4l60e?
The future goal is to replace the LR4 with a LQ9 and pump up the boost and make a lot more power.
Old 12-06-2010, 02:12 PM
update....
Got a new 4l80e with a hd2 kit and a cooler(for free)....
going to order a sexy 3500-4000ish stall(Def not for free).
Then wait for the rear end to break(get another free part when this breaks).
Old 12-06-2010, 03:10 PM
Pat-Man's Avatar
Nice! Wish I could get a 4l80e for free ... good luck with the swap.
Old 12-07-2010, 03:06 PM
charlie_gonzales's Avatar
Originally Posted by Ericmck2000
update....
where do I sign up for a free 4l80...lol
Old 12-07-2010, 04:31 PM
Get to know a lot of people and ask around, haha.
Old 12-07-2010, 04:32 PM
Im trying to barter a few of my old 454s and that th400 laying around to get ahold of a 6.0, lol.
Old 01-04-2011, 06:05 PM
Melted a hole in #8.
Put some cheap gas in on the way back from a road trip, went to pass a truck, then ses lights started blinking... And it started missing pretty bad.
Drove 250 more miles home, pulled all of the plugs, left bank was all white. Right bank was all fouled out, #8 plug was dented in.
Hooked up a compression guage, fired it over and got 0 compression.
Pulled the oil cap off and let it run for asec, it just blows smoke out like part of the exhaust. So... Pulled off the injecter / spark wires and drove it back in a corner to be worked on later. Kinda surprised the broken transmission outlasted the engine for 4500 miles. Oh well. Waiting on parts.
Quick Reply: Procharged Silverado 4.8.. Part 2. Replacing the things i cheaped on.
