Stock? heads for 370ci turbo motor
Is there a stock head that will work well on a 370ci turbo motor? I'm looking to put down 650-700 or more RWHP. I seen a 4" stroke LS1 with a small turbo put down 499 with a very mild cam and no port work on some 243 heads. Any info is greatly appreciated.
how high you want to rev ?
what sort of valve train ?
most use ls7 lifters, they are rated to 7000rpm and are the stock replacement lifters now. but for heavier valve train and big cams i would use morels or caddy lifters
