silicone 90 for stock throttle body
what are you guys using for a 90 and where did you get it? i need to go from the stock tb to the maf with a 90. does the 4" fit ok, it seems more like 3.75. and then the maf seems closer to 3.5, so i dont want to just get a 4" and it doesnt fit.
Take a measurement of your mass-air flow housing's outer diameter, and your throttle body's outer diameter, and that'll answer the question of sizes. After that, there are multiple sources you can use to get a good multi-ply reinforced coupler.
Report back with sizes, I'll report back with sources and a part number or two.
well, the throttle body is 3.925"/99.75mm and the maf is 3.67"/93.25mm
so maybe one that is 100mm on one side and 95 on the other.
but i mainly see them in 4" and 3.5". will a 4" be too big on the maf end, or is it close enough?
