Oil pan opinions? Need some recomendations
I am about to finish my build next week and I need an oil pan. I have looked at Canton and Moroso, but what are my other options? I will be doing a good bit of drag racing and an occasional drift event. I want something with a functional windage if possible.
Oiling System
I have an ARE dry sump pan and a Dailey Engineering 2 stage pump....pretty trick because it uses the factory oil pump as the pressure side and the 2 stages on the pump are strictly for evacuation of the ARE pan. Very compact...the pan clears everything....very light.....cooler, non aerated oil and adds about 30 HP on my setup (stock cube LS6,headers,Magnacharger 112,Meziere, TF 215, ECS cam,etc)...
