Vortech owners, have you replaced your BPV?
I have a V9 G-trim with the Bosch plastic bypass valve recirculating back to an intercooler. I'm considering replacing the Bosch because I haven't read great things (plastic construction, rubber diaphragm prone to failures, etc.). The ATI Procharger guys seem to love the ATI Race vented to the atmosphere. That device appears to have a flange to bolt to the plumbing, but my Vortech plumbing is setup for hoses to attach in to the BPV.
What are you using on your Vortech?
Is it recirculating or venting to the atmosphere?
What do you like/dislike about your setup?
The Vortech race bypass valve is a direct bolt on to the aftercooler. If you are recirculating you would need to either weld on a larger bung for a larger hose or neck down the hose.
I don't have the Vortech aftercooler, instead a Procharger intercooler down in the nose more like your setup. It looks like you have the same bypass setup as me with the hose running to recirculate. What bypass valve is that in your pic?
aftercooler, boost, bosch, bpv, bypass, configuration, diaphragm, guys, hose, psi, recirculate, recirculating, replace, valve, vortech
