ATI crank pin removal?
I had my crank pinned w/an ATI kit a while back by a shop.
I need to change the cam and was gonna do it at home. I was curious if I need to do anything different when I take the damper off?
Will the crank pin stay in the crank when I pull the damper off?
Do I pull the damper off just like I would any other pulley?
If the crank pin falls out, do I just push it back into the crank when I install it again?
thanks in advance
thanks in advance
