ls1 boosted map sensor
i am looking for a 2 bar map sensor for my ls1. looking for a direct plug in but i cab trim the sensor as i see you have to most the time. i have checked other threads on here but get some comflicting results. what GM part # is the sensor that i will need whether map or baro to work with the stock ls1 ecm and efi live
GM 12580698
just get that one and don't try cutting corners. I tried to get one from AdvancedAuto and it turned out to be wrong. Go to a GM deal and spend the $75, yes it's painful for what it is but trust me it will work once you plug it in.
