optimal oil return size for rearmount turbo
OK. Trying to button a few things up on this rearmount setup. I currently have a -4 feed and a -10 from the Turbo to pump and a. 5" rubber hose from pump to engine. I'm wondering if that -10 section between the Turbo and pump is to big?? Any thoughts? I'm going to try and mount my pump level with the Turbo oil outlet but it will likley be a little higher. Its a shurflo oil pump. Any thoughts?
