90* silicone TB hose.
Old 08-11-2010, 06:04 PM
TT350's Avatar
Default 90* silicone TB hose.
What are you guys doing that run stock TB’S.
The stock TB measures about 3-7/8,
a 4” silicone 90* is a sloppy fit.
I can pull it down with a T-bolt clamp
but I’m **** about details like this.
Old 08-11-2010, 06:28 PM
Tally TransAm's Avatar
4" and tbolt works no problem, seals fine
Old 08-11-2010, 06:32 PM
TT350's Avatar
Did you find that the fit was loose?
Did you have to pull it down with the clamp?
Old 08-11-2010, 06:40 PM
trans2000am's Avatar
u could always have someone weld a bead around the end of tb
Old 08-11-2010, 07:11 PM
TT350's Avatar
I can weld a bead on the TB.
I was just wondering if there was a source for one that fit better than
the run of the mill 4".
Old 08-12-2010, 09:43 PM
Pocket's Avatar
Just clamp the T-bolt down
Only piece that really needs the ring is the truck MAF, but most cheapo cone filters come with several reducer rings. Maybe put one of the bigger rings on your TB and stretch the silicone over it
Old 08-12-2010, 10:02 PM
black98ws6ta's Avatar
I like to see a better fit as well but that size will be impossible to get. Just tighten it down, never had any problems.
Old 08-13-2010, 10:05 AM
LS1Silverado05's Avatar
My 4" one fit good... Just clamp it down
Quick Reply: 90* silicone TB hose.
