1k hp guys help on set up
i am getting closer to the end of my build and i am having trouble getting a straight answer to my questions i plan on making 1k hp to the ground with my set up 408 AFR 205 custom cam pt88 turbo.
now what pcm injectors i would like to stay away from a bunch of driver boxes do i need to go BS3 if so what is needed to do so
i have a 98 tank stumped
and planed on running a magna fuel 750 pro tuner pump
this is the kit but i am running a vic jr intake and sheet metal elbow also the car has a th400 rmvb.
thanks for helping
thanks for helping
96 lb injections, driver box and stock PCM will do it just fine.
they make a 100 lb/hr high impedence injectior now which does not require the driver box also, but its really short you will have to run spacers to make it all fit up.
x2. I also run a driver box, stock PCM, and 220lb injectors. It is actually less expensive to get a lowZ driver box and run lowZ injectors than to run huge highZ injectors directly from the PCM -they are much more expensive and arguably not as precise.
What brand injectors are you comparing? It may only be at the larger sizes where the price advantage takes place. I have had zero issues with my AEM driver, I purchased it with the LS1 plug and play harness so there was no wiring/splicing/guesswork.
Restricted User
You will either need an aftermarket computer or you will have to fudge the tune. The 98 PCM is limited to 15 psi and I doubt that you will see 1000 rwhp on that combo by 15 psi. You will likely need 20+psi.
If you are going to an aftermarket PCM solution, then just buy one with the ability to run the low Z injectors. They are more precise. The aftermarket computers will integrate other things that you will need like a 2 step. So between a good 2 step and driver box you are at over $500 already towards the new computer. The downside is that the aftermarket computers wont run your stock gauges so you will either have to buy gauges, by a racepak or piggy back the stock computer.
my car is a 2000 i just have a metal 98 tank for stumping and i was thinking the same thing you are 98Z28CobraKiller about the 2 step injector drier box exc, really 1k hp doesn't matter i just want the car to run good and am not trying to buy parts twice 8.99 is my goal if i can do it with stock pcm that would be cool if not bs3 is what i was thinking
if i run the bs3 with racepak wold it still run my speedo and all necessary gauges i have heard with a race pack u need a 1500 harness to do so but i not sure i would love a racepak but i dont want to drop 6k on that and bs3
the 160# high impedance I got were a direct fit for an LS1 including the plug and the height. I wanted to minimize the chance for any screw ups.
We tuned it with HP Tuners 3 Bar Speed Density.
Idles fine, does not foul plugs at all.
BTW, they are 160# at 3 Bar and we reference 1 to 1 with boost.
Nothing against driver boxes, but I just wanted ot keep things simple.
I have 90lb inj. from injectorLLC or whater and with a 403ci and same turbo made 895 to the tire with a th400 and injectors werent maxed out. The turbo was basically out of breath
Restricted User
I ran my 8.9 on the stock 98 pcm but I was fudging the fuel. With a 2000 PCM, you shouldn't have a problem. Switching to the BS3 would be a mistake for sure. You would lose resolution and alot of scanning capabilities and like I mentioned, your gauges. Unless you piggy back the stock pcm and then it's just a clusterfuck.
