msd6010/6012 boosted timing tables? anyone care to post some?
been jacking around with my msd software and im bout to download what i think will be a good starting point, jus wanted to what others used table wise. if i understand it correctly , using the map table to remove timing during boost can be limited to max retard or advance. so if im using the map sensor to retard under boost, even if i go past 15lbs of boost it's only gonna pull out my max retard correct? guess itd be jus easier to glance at another's timing table.
