383 lt1 vortech supercharged?? on crank
Old 10-28-2010, 07:57 PM
detroit_903's Avatar
Default 383 lt1 vortech supercharged?? on crank
I have a 383 stroker lt1 camaro with a vortech supercharger. The crank is a single key. I was told running high boost the damper would break off cause it's not a doubled key.. Im running 10psi right now 600rwhp... Looking to run 15psi -- would that cause A problem or can those single key cranks hold up to higher boost?
